Re: Bleeding hydraulics on an IH 350
Armand Tatro
03-12-2007 20:32:22
The possible exists that at least one the triangle posts that the bottom of the lift cylinders and the boom attatches to are a
hyd. tank to supply crankshaft-driven pump that is behind the guard at the front of the tractor.Look for breathers; pipe fittings; ect. around that frame. A few loaders did use loader frame for hyd. tank but I might be wrong about this one. Something to check. Armand
