Powersteering cylinder question
biggerred
03-12-2007 20:55:02
I got a complete rear axel out of my old 715 IH combine. It has a cylinder for powersteering on the axel. Any way I can put the complete deal on a Super M that has live hydros and already has a behlen unit and flow devider in use? I figured I'd have to remove the behlen unit at least.
Janicholson
03-12-2007 21:06:42
 Re: Powersteering cylinder question in reply to biggerred, 03-12-2007 20:55:02
Sure, adapt the axle and Y bracket to the M and put the Control valving in the location of the Current Torque motor. That would be the most stock looking. Removing all the bolster components would also neaten it up some. Go for it. JimN
Bob
03-12-2007 21:05:31
You would need the power steering "valve" (steering column) to go along with the steering cylinder.
Older combines had a steering "hand pump" driven by the steering wheel PLUS a steering valve under the operator's platform. IIRC by the 715 era they were integrated into one unit.
