Splitting SMTA-LP
Lance_MF_180
03-13-2007 05:59:10
Any gotcha's to consider when splitting an SMTA-LP? I am going to use a cherry picker to lift off the LP Tank to get that out of the way. I drained the oil under the mid section where the TA is located. Disconnected the Hydraulic hoses to the PS and main Pump. Do I need to drain the Antifreeze? The LP pump has a line going to it from the head or should I just cap it off during this time? If the condition of the oil in this new found tractor says anything I am thinking I should just dump the antifreeze too. Also, is there a bolt in the mid-section that bolts to the rear end that you can only get to from a hole under the mid-section? Thanks Everyone! - Lance
Dave H (MI)
03-13-2007 15:34:34
 Re: Splitting SMTA-LP in reply to Lance_MF_180, 03-13-2007 05:59:10
TSC used to sell a video on splitting the MTA. Don't know how the LP version would be too much different.
Hayfarmer
03-13-2007 07:04:42
What are you going to do to it? Are you splitting between ta housing and transmission or engine/clutch housing or both(to replace ta)? I would drain all oil from the rear end if it hasn't already drained from ta section. You will want to use Hy tran or equivelent in rear end after overhaul. I beleive there is a bolt between the torque tube/ta housing and the rear end that you have to get from the bottom through the cover for the seasonal disconnect. You need to have a manuel to do the job and it really helps to have a parts book also. I always cap off everything I disconnect so that you don't get dirt or bugs in some line. You don't have to drain radiator but if you think the antifreeze is old it may pay off. The torque tube is heavy as are both ends of the tractor when split.
