Carter carburator on a 41 A
HENRY E NC
03-13-2007 18:41:11
I have recently acquired a 41 A and it has a Carter Carburator. I bekivev it was a dual fuel tractor to start with because the manifol has a heat adjustment on it but welded open.. What say you guys????
City-Boy McCoy
03-13-2007 19:29:37
 Re: Carter carburator on a 41 A in reply to HENRY E NC, 03-13-2007 18:41:11
Generally, the dual fuel carbs had an adjustable main jet (bottom area of the bowl). The gas carbs did not. Of course, someone could have changed the carb at some time. If not, then an adjustable main jet would be a good clue. Congratulations on your new toy. mike
