IH 240 utility (carb)
glen swanson
03-14-2007 05:13:31
I cannot get my 240 to run at high speed it pops and looses power, at idle it runs fine. I've taken the carb apart and cleaned it put new needle valve but no luck. Should the float have the little wire that conects to the needle valve to pull it down, mine dosen't.
thanks
glen
georgeky
03-14-2007 06:56:01
 Re: IH 240 utility (carb) in reply to glen swanson, 03-14-2007 05:13:31
That could be electrical. You may not have hot enough spark to run at high speed.
glen swanson
03-15-2007 14:54:47
 Re: IH 240 utility (carb) in reply to georgeky, 03-14-2007 06:56:01
Do you know if the float should have one of thos little springs that pulls the needle valve down, mine dosen't. I was wondering if the needle valve could be stickinf??
thanks
glen
Chrisco
03-14-2007 05:31:32
Have you cleaned your fuel line? On my 340 it does that when the line is plugged.
