Replacement Block for Super A
Hartford Mannin
03-14-2007 18:53:39
Hi,
I have a Super A with cracked block (251069R1, 5-16-T, FAAM 289624) behind the steering box. Maybe can be welded (see earlier post)? I have found a block from a C (354898R1, 5-6-W, FCM 108663). Will this block fit the Super A. Anything to watch for? It does have a water pump, the SA does not. Are things like the head, main crank, pushroods, valve cam transferable from one block to the other?
Thanks,
Hartford in Beeton
Hugh MacKay
03-14-2007 19:40:59
 Re: Replacement Block for Super A in reply to Hartford Manning, 03-14-2007 18:53:39
Hartford: The block 354898 R1 is from one of 2 tractors. Super A after serial number 310000, or any Super C. FCM indicates it is from Super C and will take SC pistons and sleeves. The water pump will work, but you will need some modification for top rad hose. Everything else will bolt up or fit.
You could also order a kit for SA after serial number 310000. SA will be 3" bore. SC will be 3-1/8" bore. You can use the water pump which ever way you go, just make sure you get the head gasket for water pump.
georgeky
03-14-2007 19:33:09
I forgot to mention there was differnt size sleeves in some of the later C 113 blocks I am not sure about the casting numbers.
gene bender
03-15-2007 03:16:14
 Re: Replacement Block for Super A in reply to georgeky, 03-14-2007 19:33:09
Different size sleeves mean that it is either a 113 or 123 or even 135 if it is a later block
georgeky
03-14-2007 19:29:57
Yes it will bolt right up. and yes the other parts are interchangable
