Order Farmall Cub Parts Online
51 Cub engine gaskets
Kurt in Va Beac
03-15-2007 18:15:20
Hi all, I'm now in the middle of putting my 51 cub engine back together and had a question about weither or not I should or where I should use gasket sealer when installing the engine gasket set. I know not on the head gasket - head is already installed and torqued to specs, but other gaskets like for the oil pump, etc. Years ago on a car I used the tacky stuff for the oil pan, but wondered about some of these other gaskets. Any comments? Thanks in advance! You all have been a great help on my other questions - Kurt
Farmall Freak
03-16-2007 17:55:51
 Re: 51 Cub engine gaskets in reply to Kurt in Va Beach, 03-15-2007 18:15:20
I agree with georgeky you don"t need any sealer on a "new" engine.
Kurt in Va Beach
03-21-2007 18:44:56
 Re: 51 Cub engine gaskets in reply to Farmall Freak, 03-16-2007 17:55:51
Thanks guys!
georgeky
03-15-2007 19:17:19
Kurt the only thing I use on gaskets is a little lithium grease on each side works great and if you have to pull for any reason most of the time you can reuse gasket.
