504 rough running, distributor/timing??
RUSTY in TX
03-17-2007 01:09:03
Resent engine rebuild, while attempting to restabe distributor, must have reversed shaft, TDC is wrong. Runs rough at high RPM & low RPM, but smooths-out a half throttle. ??? TDC? Distributor? Timing?
Roger Mills
03-17-2007 06:45:34
 Re: 504 rough running, distributor/timing?? in reply to RUSTY in TX, 03-17-2007 01:09:03
You could have the drive gear off one tooth. Find #1 compression (finger in the plug hole trick) then line up tdc and the rotor should point to #1 and points should just be opening. If so you are close. Rough idle could be mixture and same for high end--check carb and fuel flow, might be starving at high RPM.
RUSTY in TX
03-17-2007 08:47:17
 Re: 504 rough running, distributor/timing?? in reply to Roger Mills, 03-17-2007 06:45:34
Thank you for your comments. Fuel system has been completely gone-thru, if anything it may be getting too much fuel, maybe?? Is #1 cy to the left or to the right asyou face the block? sorry for stubid question!! my first time at this. there is a key-way mark on the back-side sprocket of crank shaft pully,...should this be on the very top, when #1 is at tdc??? Agin, thanks for your intrest and comment. RUSTY in TX
Janicholson Visiting TX
03-17-2007 14:23:21
 Re: 504 rough running, distributor/timing?? in reply to RUSTY in TX, 03-17-2007 08:47:17
#1 Cylinder is toward the radiator, Good luck with it. JimN
Jossette
03-17-2007 05:55:28
check tdc and then check the gap in the points to .020
RUSTY in TX
03-17-2007 08:51:54
 Re: 504 rough running, distributor/timing?? in reply to Jossette, 03-17-2007 05:55:28
Jossette, thanks for comment and intrest, I will check both. Thanks again RUSTY in TX
