1932 f-20 pic
russ hamm
03-17-2007 10:01:32
third party image
loaded this one this moening as it was going for scrap monday. s.n. 1834, not stuck and we have the steel and duckbill front end at home. looked at it a couple of years ago, but when he called this time i noticed it had a gas tank with caps like a regular and checked out the s.n. had the duckbill laying around for a number of years without a tractor.
r4etired
03-17-2007 18:37:41
 Re: 1932 f-20 pic in reply to russ hamm, 03-17-2007 10:01:32
About 5 miles from me there is an F-20. serial no 747. The 247th one built, All three serial numbers match. Her husband restored it in the 80's She wants 1500.00 for it but no takers.
Mike Androvich
03-17-2007 13:29:22
That's nice Russ. Why in the world would someone want to scrap something like that especially if it's loose? Makes absolutely no sense to me. Glad you saved it from the furnace! Did it have the tag on the toolbox?
russ hamm
03-18-2007 11:59:48
 Re: 1932 f-20 pic in reply to Mike Androvich, 03-17-2007 13:29:22
mike, no tag (darn it) looks like the tags on those are two rivet like a regular? frame number and block number match. yeah, he offered it to me a couple of years ago and others looked at it also but no takers. i thought it was just another f-20 i didn't need till i saw the gas tank and the number. also didn't even check to see if it was stuck or not back then. jeeez.
Farmallgray
03-18-2007 15:36:00
 Re: 1932 f-20 pic in reply to russ hamm, 03-18-2007 11:59:48
That tractor would have a different tag than the later tractors. It would have one that says "McCormick Deering Farmall F-20" at the top instead of "international Harvester Co." with the model stamped in.
