IH 464 Fuel Filter Plugs
David Ammons
03-17-2007 16:05:16
I have an IHC 464 Diesel Tractor. I have believed that I needed to add a Final Filter on the left side of the engine. I got a bracket that on the box says 3132198R2 Deckel. It did not come with any plugs or inlet/outlet plugs. I need two to close off inlets I will not be using and then one that allows me to connect a flex 3/8" fuel hose. I think the holes need a male plug of about 3/8" and I thought either Compression or Pipe threads. But I can't find a plug that fits, a man at NAPA says the threads are Metric. I am not sure what to use or where to find it.
Fromjb2
03-17-2007 17:15:37
 Re: IH 464 Fuel Filter Plugs in reply to David Ammons, 03-17-2007 16:05:16
Hi David, NAPA is probably correct as the fuel system on that model of tractor is German Bosch.
Good luck finding plugs.
JimB
