Clutch not Disengaging
LinemanFarmer
03-18-2007 06:15:59
I had just got my M running for the first time, I was out testing out all the gears for noise, but my clutch keep on sticking, it got worse and in the lower gears is would stick for a couple of seconds and then release and in the higher gear (4 + 5) i would have to step on the brakes to lug the engine and then it would release. Any ideas that I could try? It seems awful dangerous! Thanks in advance Derek
Andrew Z
03-18-2007 13:41:10
 Re: Clutch not Disengaging in reply to LinemanFarmer, 03-18-2007 06:15:59
I had this happen (same symtoms anyway) turns out one of the forks on the pressure plate turned in and soo when I hit the pedal I only was able to push in 2 of the forks not hitting the third one at all.
I was about to pull the clutch. and then found this and it was it.. i dont know its not the first thing I though of and aperatly its not common but look to see if all the forks are at the same distance and that the throw out bearing hits them.
Andrew
flying belgian
03-18-2007 13:25:09
It is most likly oil soaked. Run it up to tree and put it in high gear and burn clutch till it smokes. You will not hurt clutch as it is just oil smoking.
A. Bohemian
03-18-2007 09:06:57
 Try this first... in reply to LinemanFarmer, 03-18-2007 06:15:59
I was hesitant to reply to this, because I've never done maintanance on an M.
How about it, M experts? Does M have clutch inspection ports? I know it is a frame-built tractor and Model C is unicoque, so maybe not...
But Model C has TWO inspection ports in the bell housing (one of which, the one on the bottom, ALWAYS has mice nesting on it). If M has such ports you might start by locating them and opening them up and looking for something obvious.
In addition, one of the ports on Model C reveals a zerk fitting that is used to directly lubricate the throw-out bearing. Since most throw-out bearings are lifetime lubricated, many owners miss this fitting when doing routine lubrication.
If your M has such a fitting, I would probably start by hitting it with some grease, then trying to get the clutch to work back and forth on the shaft. If you're lucky, it ought to come completely free. These old tractors are very forgiving.
Then, if it's still stuck, you can start spraying brake fluid on stuff through the ports without removing the starter...
georgeky
03-18-2007 09:23:27
 Re: Try this first... in reply to A. Bohemian, 03-18-2007 09:06:57
No they do not have ports like a C.
A. Bohemian
03-18-2007 09:35:53
 Re: Try this first... in reply to georgeky, 03-18-2007 09:23:27
Okay. Thanks. It would have been a great short cut...
old
03-18-2007 07:58:20
Good chance its either rusty or oily either one will cause that problem. If its rusty block the pedal down and start the engine and let it run for a while that will knock some of the rust off. Also slipping the clutch some will help. If its from oil pull the starter and spray the clutch off with brake cleaner, turn the engine over some as you spray so as to get all over the clutch
LinemanFarmer
03-18-2007 08:04:12
 Re: Clutch not Disengaging in reply to old, 03-18-2007 07:58:20
Thanks Old, I will try that
LinemanFarmer
03-18-2007 08:04:08
