F12/14 Manifold Gasket
Fawteen
03-18-2007 11:03:33
Doing a little update on a 10 year old rebuild of my F14. One part of the project is to replace the leaking manifold gasket. Got the manifold off this afternoon, and 3 out of four of the exhaust ports had chunks blown right out of the gasket.
When I rebuilt the motor, I used the one-piece fiber gasket that came with the kit. New manifold, new head, new studs, brass nuts, all torqued down good and rechecked after a couple of heat cycles on the engine. Ordered a replacement gasket from Rice Equipment, same deal, plain fiber gasket.
Dunno if something is warped or if I just didn't reef it down tight enough, but all the intake ports looked fine.
Is there a heavier duty gasket available? Maybe something with metal crush rings around the exhaust ports?
ET
03-18-2007 15:39:12
 Re: F12/14 Manifold Gasket in reply to Fawteen, 03-18-2007 11:03:33
Put a straight edge on the gasket surface of the head and manifold to check for warpage. A framing square would work.
