Batteries 966
GordoSD
03-18-2007 13:54:01
Sure enough, sooner or later it had to happen. Left the switch on on the 966. Dead batteries. Now there are two big 6 volts on it. If I charge it with all the cables hooked up do I set my charger on 6 volt or 12 volt? The charger seems to make weird clicking sound when I tried the 12 volt position.
Gordo
GordoSD
03-19-2007 05:11:58
 Re: Batteries 966 in reply to GordoSD, 03-18-2007 13:54:01
Thanks Vet, that did the trick!
Gordo
the tractor vet
03-18-2007 14:07:04
Hook the pos. lead to the pos . battery that goes to the starter and put the ground from the charger to the frame bolt and charge 12 volts
