C123 piston ring end gaps
CSR
03-19-2007 02:59:32
I am rebuilding a C113 into a C123 using a TISCO kit. The end gaps per the IT manual are .010-.018 for all rings. I notice the new oil rings are 3 piece automotive style whereas the old oil ring was a single cast piece. The gaps I'm getting are TOP .014-.016, 2nd Compression .018-.022, and .028-.032 on the oil rings. Are these typical of a TISCO kit ? I am familiar with small block chevy's which allow up to .020 on the 2nd ring and .010-.055 on the oil rings. Does anyone have any experience with these end gaps ? or should I send them back and get another set ?
gene bender
03-19-2007 04:33:05
 Re: C123 piston ring end gaps in reply to CSR, 03-19-2007 02:59:32
If you have a new kit from TISCO the parts should be correct. If you dont like the way they fit contac TISCO
El Toro
03-19-2007 03:54:31
I think you need to measure the sleeve bore. Hal
