TISCO head Gasket - use sealer ?
CSR
03-19-2007 03:07:03
I purchased a TISCO overbore kit for a C113 and it came with a Victor gasket kit that contained a FelPro multilayer head gasket. The gasket is stamped "sealant/retorque required".
Does anyone have a recommended sealant (or none) ?
thanks.
glennster
03-19-2007 06:33:14
 Re: TISCO head Gasket - use sealer ? in reply to CSR, 03-19-2007 03:07:03
i use a spray on gasket sealer made by permatex, i think its called hi-tack sealer, it has little copper metal flakes in it to aid in sealing the head gaskets.
ChadS
03-19-2007 07:40:14
 Re: TISCO head Gasket - use sealer ? in reply to glennster, 03-19-2007 06:33:14
"Coppercoat" by Permatex spray everything, block, both sides of the gasket and the head surface. let it get good and sticky and put it together. Chad
