C113 Rear Main Seal Installation Question
CSR
03-19-2007 03:11:53
The TISCO kit contained a two piece felt rear main seal and some cork pieces to seal the split between the two piece aluminum seal carrier. The cork pieces are perfectly shaped to go all the way to the crank such that the cork is between the two felt seals. Is this the correct way to install this so the cork gasket is sandwiched between the felt ? of should the cork be trimmed back so the two felt halves can touch each other ? I assembled it with the cork in the sandwich and the crank turns reasonably.
thanks.
Red Agony
03-19-2007 15:55:06
 Re: C113 Rear Main Seal Installation Question in reply to CSR, 03-19-2007 03:11:53
The way I`ve done it is rub the felt in good with a hammer handel to get it seated,then cut it off flush with a razor knife.Then sandwich the cork as you`ve described.Don`t forget to soak the felt with oil, that helps the crank spin.
