Super C hydraulic pressure
Nate the Great
03-19-2007 10:15:39
How much hydraulic pressure "should" a super C produce? I guess that's the same as asking at what pressure the system relief valve is set, since a pump in good condition should go on relief any time you reach the end of the stroke with the cylinder.
thanks,
Nathan
georgeky
03-19-2007 10:28:51
 Re: Super C hydraulic pressure in reply to Nate the Great, 03-19-2007 10:15:39
High pressure should be between 1100 and 1500 psi and low pressure should be 15 to 40 psi.
