Super MTA - 400 shifting forks
460anger
03-19-2007 17:15:42
Are the MTA and the 400 shifting forks the same? Thanks.
D Slater
03-19-2007 18:09:15
 Re: Super MTA - 400 shifting forks in reply to 460anger, 03-19-2007 17:15:42
Shift forks are the same with same IH # on them, but the forks are welded to the shift rails. 400 and MTA transmissions are the same but on a 400 top cover the shifter opening is closer to rear of tractor so slots for the shift lever in the rails is a longer distance from the fork than a MTA rail. Also if I remember correct some of the half moon cut outs in the rails for spring loaded balls are in the wrong place.
460anger
03-20-2007 03:28:31
 Re: Super MTA - 400 shifting forks in reply to D Slater, 03-19-2007 18:09:15
Thanks guys.This is what i'am trying to do.I'am using a top cover off a m trying to but it on a 400 tranny It is a 50 or so M I took the shifting forks and rails out of a 400 and cut them the same length as the m But the problem I have now is there not long enough to shift the gears completely So i need help!!! Maybe I should of left them alone and just used them out of the 400??? Any help would be Great. Thanks
Wardner
03-20-2007 08:32:31
 Re: Super MTA - 400 shifting forks in reply to 460anger, 03-20-2007 03:28:31
I have lids from a '39 M, SMTA, 400, and 560. I have these because I wanted 560 ratios and bearings in a SMTA and I also wanted a 400 lid so I could run a early fast hitch on the same SMTA.
I made these alterations some years ago so I can't sit here at the computer and tell you exactly what I did. I think I used the SMTA forks/rails, rail retainers, and shifter with the 400 lid.
I probably have what you need.
Wardner
03-20-2007 08:46:33
 Re: Super MTA - 400 shifting forks in reply to Wardner, 03-20-2007 08:32:31
Building on what D Slater said, I could do the machine work as I have a welder and a Bridgeport. However, I don't think that is necessary. I can look at the parts side by side and take some photos. I seem to recall that the front rail retainer needs to be notched about an eight of an inch. If using the 400 lid, you will also have to modify it for the steering column.
D Slater
03-20-2007 09:17:36
 Re: Super MTA - 400 shifting forks in reply to Wardner, 03-20-2007 08:46:33
Wardner if I understood correct he's trying to put a M cover on a 400 rear. If you put a 400 cover on a MTA you should have been able to use the 400 shift forks with it because the transmission housing and everything in is just like a 400. If you have a set of MTA shift forks and rails left over thats what size he needs to put a 50 M cover on a 400 or SMTA rear end and make it work.
460anger
03-20-2007 10:09:59
 Re: Super MTA - 400 shifting forks in reply to D Slater, 03-20-2007 09:17:36
That sounds like what i need (MTA rails and forks)If anyone has some let me know Thanks I will need all 3 Maybe the holder to
D Slater
03-20-2007 04:04:09
Have looked at using 400,450,560 shift fork and rails in MTA before but its not fresh in my memory. It could be managed by some good machine work. Seem to remember some slots and indents could just be recut but some would need filled and recut. Be hard to do without having some MTA forks to get the measurements from.
Wardner
03-19-2007 17:35:54
My recollectiion is they will interchange but one rail is slightly different; MTA 1st/reverse is slightly shorter. That can be corrected by altering the rail guide. D Slater will have more details. Stay tuned.
