Transmission/Gearbox Oil
cannonball
03-19-2007 17:22:28
What kind of gear oil should go in the rear end and PTO box for a Farmall C?
Will Sick
03-19-2007 22:45:37
 Re: Transmission/Gearbox Oil in reply to cannonball, 03-19-2007 17:22:28
Gear oil should be GL 5 90. GL5 will stand up to the pressure where the gear teeth meet. It means gear lube 5
Gary Puckett
03-19-2007 19:31:52
I have been trying to decide the same thing for an H. Where can you find straight 90 weight? Is GL 1 90 ok?
georgeky
03-19-2007 19:59:47
 Re: Transmission/Gearbox Oil in reply to Gary Puckett, 03-19-2007 19:31:52
Yes it will.
Gary Puckett
03-19-2007 20:34:12
 Re: Transmission/Gearbox Oil in reply to georgeky, 03-19-2007 19:59:47
Does the "Ky" mean Kentucky? I am from central KY.
georgeky
03-19-2007 21:24:22
 Re: Transmission/Gearbox Oil in reply to Gary Puckett, 03-19-2007 20:34:12
Yes it does, I am from Winchester.
jddozermike
03-19-2007 18:25:49
Hm , guess i did it all wrong then, I was told 30 wt motor oil. Better change that!
Steven@AZ
03-19-2007 18:21:00
90 weight will work fine, I personally prefer 85W-140 as I use my tractors for real work, year-round.
georgeky
03-19-2007 18:30:40
 Re: Transmission/Gearbox Oil in reply to Steven@AZ, 03-19-2007 18:21:00
Either will work good I work my old tractors also year round and I always thought the 85/140 may be a little heavy in cold weather.
georgeky
03-19-2007 17:38:14
Any good 90 weight oil works great.
