Good news/Bad news!!
Roger Mills
03-20-2007 08:19:45
First tractor show around here this year and I took my A. It was at a park about two miles away so I drove the tractor rather than loading it. Good news-only red one there-its green country. Lots of folks had never seen what one guy called a 'side saddle' tractor. Bad news-front seal leaks bad and I had oil running down the RH side of the block from the head gasket between #3 and #4. To this point I had only driven it around the yard. It sat most of the winter snowed in. Good news-all gears are quiet and so is the diff, (slight whine but no clanks or clunks). Bad news-forgot that the brakes barely work. Good news-it is flat roads and only 3 stops. Bad news-one front rim is bent. Good news-oil pressure mid scale at idle when hot. Bad news-governor output shaft leaking oil. All in All-a great time and I'm glad I went-so what if I have to pull the whole front of the tractor apart.
Peabody
03-20-2007 09:00:51
 Re: Good news/Bad news!! in reply to Roger Mills, 03-20-2007 08:19:45
Good news - If a Farmall's not leaking oil from somewhere, it means it's running low!
georgeky
03-20-2007 09:33:21
 Re: Good news/Bad news!! in reply to Peabody, 03-20-2007 09:00:51
I have lots of farmalls that dont leak oil anywhere. After 50,60 or 70 years lots of gaskets and seals need replacing. I also have 3 or 4 that leak all over, I have not replaced gaskets and seals yet.
