VALVE ADJUSTMENT SEQUENCE
DAN SP
03-20-2007 12:10:29
A LONG TIME AGO THERE WAS A POST SHOWING THE VALVE ADJUSTMENT SEQUENCE FOR IH ENGINE WITH FOUR AND SIX CYLINDER ENGINE YOU COULD PRINT IT OFF I AM WORKING ON A FOUR CYLINDER IT WHEN SOMETHING LIKE TDC ADJUST 1235 VALVE ROLL OVER 180 AND ADJUST 4678 I THINK ? OR DOES SOME KNOW WHERE THAT POST IS
teddy52food
03-20-2007 18:05:19
 Re: VALVE ADJUSTMENT SEQUENCE in reply to DAN SP , 03-20-2007 12:10:29
I agree with Bob . If you are off a few degrees it doesn't matter. The other way ,if you are off it will affect the setting.
Jossette
03-21-2007 17:36:53
 Re: VALVE ADJUSTMENT SEQUENCE in reply to teddy52food, 03-20-2007 18:05:19
straight from an IH machanic.
TDC compression do 1,2,3,and 5
One turn of the pulley to TDC mark and do 8,7,6, and 4.
Jossette
03-20-2007 15:17:48
if your 180 degree, is one turn with the pully to the TDC mark again, then you are right.
Bob
03-20-2007 13:09:26
 Here's the Blue Ribbon method... in reply to DAN SP , 03-20-2007 12:10:29
Link
You'll have to paste this into your browser as this site does NOT allow it to be posted as a link.
Doc Larry
03-20-2007 16:55:44
 Re: Here's the Blue Ribbon method... in reply to Bob, 03-20-2007 13:09:26
Bob
03-20-2007 20:48:27
 Re: Here's the Blue Ribbon method... in reply to Doc Larry, 03-20-2007 16:55:44
Doc...
Didn't believe me about the funny Cub Manual Server link behavior huh?
I've even emailed YT about it; with no resolution.
"Cut and paste" is the only method that works.
Doc Larry
03-21-2007 04:57:49
 Re: Here's the Blue Ribbon method... in reply to Bob, 03-20-2007 20:48:27
Duhhh...
It worked in the preview window, and worked in the past. But you get the Right Award today :)
Larry
Thack
03-20-2007 12:41:12
third party image
Here is this also.
Bob M
03-20-2007 12:30:49
Simplest way is to simply work thru the firing order. Start with the #1 cylinder when it's at TDC (compression) and adjust both #1 valves. Now roll the engine 180 deg (4 cyl) or 120 deg (6 cyl) and adjust both valves for the next cylinder in the firing order. Keep repeating for two full crank revolutions and the valves for all cylinders will have been set.
For a 4 cyl IHC engine (1-3-4-2 firing order):
- Start at #1 TDC compression and adjust both #1 valves.
- Roll the crank 180 deg and adjust both valves on #3 cyl
- Roll another 180 deg and adjust both valves on #4 cyl
- Finally roll another 180 deg and adjust both valves on #2 cyl.
