magneto spark
javan
03-20-2007 18:25:50
I took out the middle wire on my dist. cap. coming out of the magneto. I then held it next to a ground, my spark was only about 1/16th inch long (or less). Is this all the bigger the spark is? or do I need to rebuild the magneto.? thanks
JT
03-21-2007 06:55:57
 Re: magneto spark in reply to javan, 03-20-2007 18:25:50
As Old said, if it dos not jump a minimum of 1/4" not matter what method you are using to start it, a crank or electric starter. All the impulse does on a mag is to retard the timing so you can start it with a crank
Roger Mills
03-21-2007 12:58:48
 Re: magneto spark in reply to JT, 03-21-2007 06:55:57
Bob I think JT was thinking distributor ignition not magneto.
Bob
03-21-2007 09:52:51
That's absolute B.S.!
The impulse; besides retarding timing at cranking speed; makes for a MUCH HOTTER spark at cranking speed by causing a rapid change in the magnetic field in the mag's coil as the rotor "snaps" forward.
No impulse operation @ cranking speed equals slow change in the magnetic field in the mag's coil which equals weak spark at cranking speed.
Period.
Roger Mills
03-21-2007 05:44:43
Were you using the starter to crank it over? Sometimes the impulse coupler will dis-engage early. Try the had crank and listen for the impulse to snap-if you hear it AND the spark is still that weak try a new condenser and points, if that doesn't help the coil is probably arcing internally.
old
03-20-2007 18:31:54
That spark shold jump a good 1/4 inch or better and be a brite blue color. If it isn't you have problems
