SM Diverter
Todd L
03-21-2007 14:24:42
I have a stage 2 Super M. I'm installing a hydraulic diverter to power the powersteering. First question, is the smaller hydraulic line running between the reservoir and the pump on the right hand side the high pressure hose? Also, on the left hand side of the hydraulic reservoir next to the clutch pedal, there are two ports off the reservoir. Are they high pressure or return?
Allan In NE
03-21-2007 15:36:49
 Re: SM Diverter in reply to Todd L, 03-21-2007 14:24:42
"Think" my pump came off a 300; don't know if it is the same as yours or not. Anyhoo, the outside fitting on the pump block is the pressure.
Allan
third party image
Owen Aaland
03-21-2007 15:02:43
What you want is a priority flow divider valve set to about 3 gallons per minute. This type of valve will insure that all the oil flow goes to the steering first until the 3 GPM is met. Any oil flow in excess of the 3 GPM will then go to the regular hydraulics. Plum this in the pressure hose between the pump and the regular control valve. Run the priority flow to the steering motor and a return from the motor back to the reservoir. Everything alse on the hydraulic systrm can be left as is.
