Farmall H Hyd. Break-Away Coupling Bracket.
John in Ct
03-21-2007 17:10:21
I am installing a Remote Control Attachment on my Farmall H. The origional style Break-Away Coupling Bracket # 353208R91 is no longer available, I want to keep it as origional as possible and at the same time, want to use modern style hydraulic quick disconnet couplings. Any ideas? Where exactly would I mount it and how? I was planning on getting the same exact hoses 3/8' X 47" made tomorrow, would I need a different length? Thanks!!!!
Nat 2
03-21-2007 19:17:47
 Re: Farmall H Hyd. Break-Away Coupling Bracket. in reply to John in Ct, 03-21-2007 17:10:21
Tractor Supply has all the parts you need. It won't cost you too much, and nobody will be able to tell the difference.
Steven@AZ
03-21-2007 19:04:34
I don't believe there was an option for a break-away coupling from the factory - but not 100% sure on that. I set mine up with modern ISO couplers and breakaways...
third party image
PaulW_NJ
03-21-2007 18:48:23
Just saw this on eBay the other day . . . I think this may be what you"re looking for:
gene bender
03-21-2007 17:34:46
The H didnt have break-away when new so anything you end up using will be just fine. Most used a piece of 1/2 pipe running along the seat to the rear of the platform with short hose going to the pump welding a short piece of metal to bolt the rear fast. Any thing will work as i said because factory didnot have anything.
