450 hydraulics
farmallkid1958
03-21-2007 18:22:04
I have a 450 and the outside/rear hydraulics only has one way [up] no down pressure. It doesn"t matter which way you have the valve control on the main block [the shaft that is about 1" dia. with the flats on it for a wrench] any Ideas what could be wrong? How hard to fix? Thanks
ChasK
03-22-2007 09:55:54
 Re: 450 hydraulics in reply to farmallkid1958, 03-21-2007 18:22:04
The operators manual cover this issue some. If you have never had double action, it could be that the control bushing is set to 'single action'. I think it sticking out of the hood right by the leavers. Turn that to the right.
ChasK
03-22-2007 09:58:29
 Opps in reply to ChasK, 03-22-2007 09:55:54
I'll read the WHOLE question next time....
georgeky
03-22-2007 06:37:27
Sounds to me like there is a stuck flow control valve. On the side of batterey box there is a box that the hoseses are hooked to< I suspect that your trouble is in that. I had one on my 350 done the same thing 8 or 9 years ago. I use it to pull a two row trailing tobacco setter, I got to end of field raised it up and it would not go back down. I did not fix that one as I had one from another parts tractor. I switched them and mine has worked every since. I think the book calls it a check valve. I may have another if you find that is the problem.
Brownie450
03-22-2007 06:00:40
Consider plumbing the hoses up to the remote that works?
farmallkid1958
03-21-2007 23:35:42
This tractor does not have a fasthitch on it, just a straight drawbar. The rear port usally used for the cylinder on the fasthitch is the one in question. Right now the outside lever is set up and used for a rear remote. I need to use it for a V rake and it will not fold the rake out but it will retact the rake back into the transport/lifted position, or if you switch the hoses, its vice versa. I have hooked this rake up to my New Holland TN75 and the rake folds out and retacts the way it should. So its in the hydraulic block itself. The second/middle lever has preasure in both up and down positions.
ejr-IA.
03-21-2007 18:38:59
Does the cylinder retract or does it not move?Theirs a pin on the bottom of the cylinder if re moved it will not have down pressure.
