Re: Char-Lynn Pwr Steering on M
GordoSD
03-22-2007 05:25:18
I have the same problem with my SMTA. It is in fact a CharLyn. I have the new steering shafts made. Can I just bolt the control valve to the existing gauge plate with a little drilling, or does the "kit" come with a special heavy duty mount plate?
Gordo
GordoSD
03-22-2007 06:32:08
 Re: Char-Lynn Pwr Steering on M in reply to GordoSD, 03-22-2007 05:25:18
I liked the part in the instructions where it says to lower the hood on the installed unit, mark the places where the hood interferes, and "form" the hood with a ball peen hammer!
Gordo
Bob M
03-22-2007 07:09:02
 Re: Char-Lynn Pwr Steering on M in reply to GordoSD, 03-22-2007 06:32:08
The installer followed the Charlynn directions exactly when the kit was installed on my Super M! (The hood was indeed beaten out slightly from the inside to make room for the steering motor.)
Fortunately this "body work" is not noticeable unless you are right on top of it.
Bob M
03-22-2007 05:49:48
Gordo - The kit included a special bracket to support the steering motor and gages. However I don't see why the existing gage bracket cannot be cut/drilled as required to do the job.
