Farmall H Remote Control Valve question
John in Ct
03-22-2007 06:38:59
How much wear is ok between the lever that actually moves the spool and the valve body assembly (top and bottom halfs)? My concern would be dirt getting in. Thanks!!
Janicholson
03-22-2007 13:25:00
 Re: Farmall H Remote Control Valve question in reply to John in Ct, 03-22-2007 06:38:59
If there is enough wear to allow noticable slop in the lever action (about .010" at the pivot) I would think about drilling the hole oversized and inserting a larger pin. They could also be rebushed at a machine shop, and refit with the same diameter pin. JimN
