planter for SuperA
CharlieSeal
03-22-2007 07:50:40
Can someone tell me where i can find some replacement parts for the dual bin planter on my SuperA?
Jim in NC
03-22-2007 15:01:47
 Re: planter for SuperA in reply to CharlieSeal, 03-22-2007 07:50:40
Try Fitts in Cascade, Va. I have number at home, not here at friend"s house.
CharlieSeal
03-23-2007 05:05:01
 Re: planter for SuperA in reply to Jim in NC, 03-22-2007 15:01:47
Thanks for the info. I will check them out.
Jim in NC
03-23-2007 05:54:13
 Re: planter for SuperA in reply to CharlieSeal, 03-23-2007 05:05:01
Try this# for Fitts Area Code may have changed 434-685-7850
CharlieSeal
03-23-2007 06:01:59
 Re: planter for SuperA in reply to Jim in NC, 03-23-2007 05:54:13
Thanks for the number and i also found their web site. www.samstractor.com/salvage.html
georgeky
03-22-2007 09:11:49
Charlie, what parts? Depending on which one you have I have some planter parts
CharlieSeal
03-22-2007 11:39:35
 Re: planter for SuperA in reply to georgeky, 03-22-2007 09:11:49
I need the ring gear that drives the seed plate and the round plate that holds the seed plate in place. When I got the planter it only had one side operational. I also have a corn seed plate that is supposed to have 8 ports but it now only has 6 ports and is so loose that corn will get under it and freeze the system and break a chain.
Thanks for your response
Charlie
georgeky
03-22-2007 12:56:43
 Re: planter for SuperA in reply to CharlieSeal, 03-22-2007 11:39:35
Charlie all seed plates are not the same. Some are thicker than others. The thinner ones require a filler ring to take up slack, they come in 4 or 5 different thicknesses. They fit under the plates to raise plate so this dosen't happen. If you will take the plate out and look on it there will be a number. If you can tell me the number I can tell you which filler ring you need. If you will find a part number on the pieces you need I think I do have them. I may also have a extra set of plates.
CharlieSeal
03-23-2007 05:43:38
 Re: planter for SuperA in reply to georgeky, 03-22-2007 12:56:43
The seed plate hold down number is RA7037.
The corn plate has these markings:
Small Corn IH C
CPC 5044
I also have a Jumbo Shelled Peanut plate CP 5194
and a Spanish shelled peanut plate R 7032
They also have an additional set of numbers
Gear 7 9 12
Dist 14 11 8
What do those numbers mean?
Thanks for your help with this.
The duplex planter body did not have any writing on it that i could find.
georgeky
03-23-2007 07:03:42
 Re: planter for SuperA in reply to CharlieSeal, 03-23-2007 05:43:38
Sorry Charlie, the 1949 book I have shows none of those numbers. Maybe your planter is completely different than the 4 I have. I went and looked at the old junk planter, and there isn't a number on it that matches your hold down number. I expect I was thinking of a different type planter all together. The ones I have all have the same type planters on them. C221,250,C220 and a old HM planter. Maybe some of the suggestions from the other guy's will be of help to you. Sorry
Charlie N Seale Jr
03-23-2007 09:06:53
 Re: planter for SuperA in reply to georgeky, 03-23-2007 07:03:42
Thanks for trying.
I will keep looking
CharlieSeal
03-22-2007 12:15:34
 Re: planter for SuperA in reply to Brad in TX, 03-22-2007 08:11:09
Thanks for your information. I will check it out.
