How much hp? 806
Tan67
03-22-2007 18:24:00
Link
Hares the picture of the turbo thats on my 806. If theres anyone who didnt get my question from the other day I was wandering how much hp this tractor might be pushing with the Schwitzer 3LD turbo witch is used on the 12/1456 series tractors and with the feul cranked up about 10-15% but still has the DT 361 on it.any info will be gladly apriciated THANKS Tan67
chadd
03-23-2007 11:36:03
 Re: How much hp? 806 in reply to Tan67, 03-22-2007 18:24:00
Take a picture of the other side of the block so that we can see the block numbers. To me, it looks like your tractor had a transplanted motor. That doesn't look like an M&W kit, or any aftermarket kit. Every part that I see on that motor is directly off of a 1206. So either:
a)someone transplanted the entire DT361 from a 1206
or b)someone took the manifolds, turbo, plumbing, etc. from the 1206 engine and placed them on your D361.
Either way, it ain't factory. Lastly, if you want real, accurate horsepower numbers, you will have to dyno it. We can guess all we want, but the only way to really know is to run it and see what it does.
billde
03-22-2007 20:03:21
If your engine is original it is a D361 not a DT361. I wouldn't push it past 125 the D361 was not designed for the turbo.
ejr-IA.
03-22-2007 19:41:29
115 to 120
K.B.-826
03-22-2007 19:12:16
You'll never know until you run it on a good dyno. My guess would be around 125.
williamf
03-22-2007 18:56:43
third party image
Here it is. I think.
Just copied and pasted the url form your post into the box labeled "Optional Image Url." Good Luck, Wm
Tan67
03-22-2007 18:25:29
Guys i screwed up dont even reply I still havent got the picture thing fiquered out thanks.
