Up date on 240 Farmall
cole
03-22-2007 18:49:46
Thanks in advance for everyone's help on my 240 Farmall. You guy's are so helpful. I have found a friend who will work on my transmission at a decent price.(my fourth gear was out). Now the questions. Is there any other transmission that will interchange with my 240 farmall, like a C Super C, 200 or 230, just in case I don't find a salavge Farmall 240. Thanks again.
georgeky
03-22-2007 20:55:20
 Re: Up date on 240 Farmall in reply to cole, 03-22-2007 18:49:46
I think any of those will work. you should get upper and lower as there may be difference in some gears. or count teeth and check part numbers
Jim Becker
03-22-2007 20:54:55
A lot of the parts are the same in the earlier models. Unfortunately, the fourth gears are one of the few things that chenged with the 240, unless you happen to be dealing with the high speed third gear option.
You probably need to be checking the Parts Catalog for the specific pieces you need and check tooth counts to see if it would make speed differences that matter to you. If you install used gears, be sure to change gear pairs together.
