H counter shaft
Al in Mn
03-22-2007 19:10:23
I am trying to restore a 1940 H and replace the old style PTO with the newer kind. I removed the old counter shaft and the counter shaft that is required for the newer PTO is longer and am having a difficult time getting it back into the transmission. Do you have to take all the gears off and put the gears back on inthe transmission? I have done this before and this time I can't get the job done. Thank you in advance.
Owen Aaland
03-23-2007 07:24:28
 Re: H counter shaft in reply to Al in Mn, 03-22-2007 19:10:23
The shaft assembled with gears should fit back in the rear frame but you must not have any bearings installed on the shaft or housing.
