Stuck rings on farmall A
tyler Cohrs
03-23-2007 05:33:48
It has good oil preasure and starts and runs really good but smokes alittle blue. What is a good way to free the rings? Sea foam,atf
old
03-23-2007 08:20:16
 Re: Stuck rings on farmall A in reply to tyler Cohrs, 03-23-2007 05:33:48
As rusty says but if you still want to try something that is cheap and will either work or will not help just fill the cylinders with tranny fluid and let it sit a day or 2. Then turn it over the clear the cylinders and give it a try. If its stuck rings the tranny fluid will probably do the trick and it will cost you less then $5
gene bender
03-23-2007 06:49:17
You need a compression test as that will tell you a lot remembering it is not what it reads but more important the have all cycls read close. This will tell you that there is not a bad cucl but they could all be weak.
Janicholson
03-23-2007 06:03:01
It is reasonable to try ATF then Sea Foam to attempt the improvement of the oil consumption, I (however) agree with Rusty, unless there is reason to believe it has stuck rings, it probably has Mega hours. New parts help that problem. Good luck, JimN
RustyFarmall
03-23-2007 05:35:29
Are the rings stuck or are they simply worn out?
