Farmall H has dipstip
Sonnyday
03-23-2007 10:17:11
The H I have has a dipstip in the block. I'm guessing this block is from another model. Which models started having dipstips? Thanks.
JFAVOR
03-23-2007 19:49:58
 Re: Farmall H has dipstip in reply to Sonnyday, 03-23-2007 10:17:11
MY 51 H HAS A DIPSTICK. SERIAL #'S MATCH SO IT MUST BE ORIGINAL.
georgeky
03-23-2007 20:33:21
 Re: Farmall H has dipstip in reply to JFAVOR, 03-23-2007 19:49:58
Jfavor It is after market add on there were no dipsticks on Hs from factory,but could be added. There were no dip sticks until the 00 series on farm tractors. It should have pet cocks on oil pan if it has original pan on it.
City-Boy McCoy
03-23-2007 18:48:54
 Watch Out, Boys! in reply to Sonnyday, 03-23-2007 10:17:11
It's SonnyDay, or SunnyDey, again. More fun and games with this chap who discovers every rare farmall ever made. Yeah, right!
Hugh Mackay
03-24-2007 02:45:15
 Re: Watch Out, Boys! in reply to City-Boy McCoy, 03-23-2007 18:48:54
Mike: My guess is the H found a dip stick, when Sonny found the H.
NDS
03-23-2007 12:45:03
The blocks have boss for dipstick cast in it is just a matter of drilling them this was often done. If block is from combine or stationary engine it should have boss for fuel pumo with a cover held on by 2 bolts on left side.
Nat 2
03-23-2007 10:24:57
DipSTICK, maybe?
Power unit engines had dipsticks. I think they started putting dipsticks in the '50 series tractors.
Look the engine over. You should be able to find its displacement cast into the block, "C1XX", the date code in the format, "11.22.X", a serial stamped into a machined flat spot on the block.
chadd
03-23-2007 11:06:59
 Re: Farmall H has dipstip in reply to Nat 2, 03-23-2007 10:24:57
Did the H get the dipstick early or something? We had a 52 Farmall M and a 1951 McCormick W6 and neither one ever had a dipstick. Both used the drain cocks.
georgeky
03-23-2007 12:24:50
 Re: Farmall H has dipstip in reply to chadd, 03-23-2007 11:06:59
I think is is jacking you all around again.
