Do you no?
NCFARMALL-C
03-23-2007 12:28:54
I have a 1949 Farmall C and would like to no the HP and the weight of the tractor with rear wheel weights off the tractor.
Thanks
NCFARMALL-C
Charles Norwood
03-23-2007 18:08:50
 Re: Do you no? in reply to NCFARMALL-C, 03-23-2007 12:28:54
Guy Fay's data book, which I consider to be the most accurate source says 18.5 drawbar and 20.5 belt. These are IH figures. Weight is 2780 lbs less fuel and water. Rear wheel weights are 145 lbs each, so it is easy to exceed 3000 lbs.
georgeky
03-23-2007 19:56:39
 Re: Do you no? in reply to Charles Norwood, 03-23-2007 18:08:50
Charles, I dont have Guy's book, but I have never seen anything on a straight C that gives it over 19 pto hp.Does it give belt pulley,pto and drawbar?
georgeky
03-24-2007 19:52:29
 Re: Do you no? in reply to CNKS, 03-24-2007 19:34:23
I got my figures from Nebraska tractor test no 395 for a C
georgeky
03-23-2007 12:45:33
PTO 19.91 HP drawbar 15.0 and shipping weight is 2845 lbs
