hoes
Mike Mix
03-23-2007 13:20:20
Does anyone know where to find a return hydraulic hose for a international 3414 industrial tractor. This hose fits at the bottom of the hudraulic tank. Farmall dealer says its not made any more. Its a molded rubber hose with 3 connections 3/4", 1", 11/4". thanks Mike
El Toro
03-23-2007 16:43:11
 Re: hydraulic hose in reply to Mike Mix, 03-23-2007 13:20:20
Here's several places to contact. I would send them a picture of the old hose. You may be able to get it made in your area as Jay suggested, if you have a store that sells and makes hydraulic hoses. Hal
hosecraftusa.com
hydraulichose.com
JayWalt
03-23-2007 14:49:15
 Re: hoes in reply to Mike Mix, 03-23-2007 13:20:20
if you're not after originality, most hydarulic shops, or semi repair shops should be able to make you up a hose. I dont know of a source for original hoses.
