tisco overhaul kit for super m
glennster
03-23-2007 14:30:16
was looking at the tisco kit on this site for my super m. says overbore 4" to 4-1/8. im a little confused. will those sleeves fit in a standard super m that the block has not been bored? or does the block need to be bored so these sleeves fit?
El Toro
03-23-2007 14:38:45
 Re: tisco overhaul kit for super m in reply to glennster, 03-23-2007 14:30:16
They will fit without any machining to the block.
Hal
glennster
03-23-2007 14:42:30
 Re: tisco overhaul kit for super m in reply to El Toro, 03-23-2007 14:38:45
thanks, i wasnt sure and would hate to have the motor poked out, and then have the sleeves fall thru the hole. and..... ..... that hustler you found for me is ready to mow.....new blades, belt, tune up, fluid change...runs like a top!!!!!
El Toro
03-23-2007 15:16:07
 Re: tisco overhaul kit for super m in reply to glennster, 03-23-2007 14:42:30
I had forgotten about that Hustler. You will soon need it. Hal
