FH pics for BOBM25
Wardner
03-23-2007 15:10:40
I have two SMTAs with the 400 FH. I used three-spool valve bodies. Two levers control the cylinders and the third one is for the remotes. Both valve bodies are bolted to a bent-up plate that is secured to the tractor with the frame cover bolts.
One tractor has a 400 cover. The other has a homemade bracket.
third party image
third party image
third party image
third party image
third party image
karl f
03-23-2007 15:58:14
 Re: FH pics for BOBM25 in reply to Wardner, 03-23-2007 15:10:40
pretty cluttered platforms. i prefer the newer or older machines' operator stations for frequent mounting and remounting for that reason. but still love these old ones.
question: on the pic of the rustier one, there are hoses attatched to all the ports on the lift cylinder. where do the bottom two goto?
judging from the pics i assume you have your side mounted cylinder (forgot its function--leveling?) hooked up too on both.
-karl f
Wardner
03-23-2007 16:56:47
 Re: FH pics for BOBM25 in reply to karl f, 03-23-2007 15:58:14
Karl,
That was a good question and I couldn't remember why the extra hoses. So I went out to look and take some pictures.
That tractor was my first large framed IH and I have put alot of homemade attachments on it. At one point I had FH boom and hydraulic gypsy head winch hanging off the back. I used it to raise and lower trash racks and stop-logs at a gov't dam. I assume it ran the boom tilt or the winch but I can't explain why the plugged fittings are facing forward.
The forward set of hoses on the three-spool valve run the small depth control cylinder.
I hope someone doesn't bust my balls for not running a PTO shield.
third party image
third party image
georgeky
03-23-2007 15:46:48
Wardner, I am glad I am not the only one with old rusty tractors.
