holes?
DQkid
03-23-2007 18:51:32
third party image
What are the two holes near the top of the lift arms on a 460 for? one is a little larger than the other and at a different angle
ejr-IA.
03-23-2007 19:45:22
 Re: holes? in reply to DQkid, 03-23-2007 18:51:32
You put the fast hitch lift arm shafts in these holes to make the fasthitch solid instead of in the rock shaft that raises it up and down.
georgeky
03-23-2007 21:41:24
 Re: holes? in reply to ejr-IA., 03-23-2007 19:45:22
Please explain to me how that works. The things are different one sets one way and one the other. On top of that the one on the left side is to small for the lift arm pin to fit in. The right side might work, but it is impossible for the left to work. I just went out and tried before posting this response. I do know for a fact that the mowing machine is designed to work on this. With the pin in bottom of cylinder the hitch is solid and don't need this.
ejr-IA.
03-24-2007 10:31:17
 Re: holes? in reply to georgeky, 03-23-2007 21:41:24
Wish I could get you a photo but can't. Standing behind the tractor the left lift arm has a 1/2 "pin and cotter key that hooks too the rock shaft pivot that attachs to the small hole on the left on the right you take the hole pivot out of the rock shaft and that goes in the big hole.
georgeky
03-24-2007 15:07:51
 Re: holes? in reply to ejr-IA., 03-24-2007 10:31:17
I see what you are talking about, I did not try but it does look like it will work. However the mower does fit on the right side with the chain I spoke of and it is original, so I sumise that it has more than one purpose.
georgeky
03-23-2007 19:01:39
They are for sway chains on certain mounted implements. I have a 100 mowing machine that uses one of them. I am not sure what the other fits or is for. The mower has a chain about 3 feet long with a pin that fits in one hole to keep it from going down to far and swaying from side to side.
