Model A, 1945, miss fire?
Everett Martin
03-23-2007 21:53:19
My model A Farmall runs pretty good, but I can detect a slight miss-fire (in one cylinder I believe). When idleing there is a detectable "puff-back" in the exhaust tone. If I lug the engine slightly, say in 4th gear, the miss-fire is more noticeable to me. I have gone through the mag, put on new spark plug wires and changed the plugs. I have not compression checked the individual cylinders.
Any advice/thoughts will be appreciated.
Everett Martin
03-24-2007 20:46:49
 Re: Model A, 1945, miss fire? in reply to Everett Martin, 03-23-2007 21:53:19
Thanks Gentlemen for responding to my question. I will get the compression test done right away. What readings should I be looking for?
El Toro
03-24-2007 04:28:26
I would check that valve lash too. Hal
georgeky
03-23-2007 22:38:32
Do the compression check. You may have a burnt valve.
A. Bohemian
03-24-2007 11:13:50
 Good eye. in reply to georgeky, 03-23-2007 22:38:32
Actually, you've done three compression checks:
Quote: "My model A Farmall runs pretty good, but I can detect a slight miss-fire (in one cylinder I believe). When idleing there is a detectable "puff-back" in the exhaust tone. If I lug the engine slightly, say in 4th gear, the miss-fire is more noticeable to me."
I think you have low compression on one or more cylinder(s), and you have sucessfully diagnosed the problem with this tractor, using your ears and a little careful observation; I think you can confirm it by doing the individual compression checks.
I'm sorry it might need engine and/or valve work but you've done a good job figuring it out!
