Super A motor quits running
Denny Tart
03-24-2007 12:53:15
My Super A Farmall cranks right up but once it gets hot, it chokes up and then stops.
I have put a carb kit and new spark plugs.
What would be my next step?
Thanks.
Dave BN
03-24-2007 14:26:38
 Re: Super A motor quits running in reply to Denny Tart, 03-24-2007 12:53:15
Check to see if you have spark from one of the spark plug wires and from the coil wire when it quits. That will help to narrow it down. Dave.
CNKS
03-24-2007 13:01:39
Probably a coil or condensor problem, or the outlet in your gas tank is partially plugged. If it is the coil, it will not start immediately after it dies, but usually has to cool a few minutes. Other possibilities--you have a clogged passage in your carb, if you did not clean it well. There is an inline filter in the fitting that the fuel line screws into at the carb that may need to be replaced or cleaned.
A. Bohemian
03-24-2007 14:29:32
 Re: Super A motor quits running in reply to CNKS, 03-24-2007 13:01:39
When it "chokes up and dies," is it sudden or does it sputter for a while first?
Is the exhaust good and clear? Does the color of the exhaust change when it dies?
You say it dies when the tractor gets "hot." Coils often fail under temperature stress. Next time yank a spark wire and do a spark test RIGHT AFTER it dies.
But I'm curious about the exhaust...
