TD_9
sniggy
03-25-2007 05:02:28
I have a 1946 model TD-9 tractor, what I'm looking for is the fuel injector line for the #4 cylinder. The tractor is equipped with a bosch pump. These things are not easy to find. my problem is that the tractor doesnot have an ID plate. The other thing that i'm looking for is the shifter fork for first and reverse. mine is badly worn and the trans jams. when you shift into rev. the lever moves over the gear and the trans. stays in neutral .i would sincerely appreciate any help you could offer. thanks
dej(jed)
03-26-2007 10:31:01
 Re: TD_9 in reply to sniggy, 03-25-2007 05:02:28
Try Mike at the Steel Wheel ranch. He should have what you need. Heck most of those tractor were junked a while ago.
Janicholson
03-25-2007 07:45:30
An injection line can be fabricated by a good diesel shop (if they have an original (especially the fittings) It is not brake line, and may be pricy.
The shifter fork can be built up by a professional welder and surface ground on a machine to specification, or fit. I have done many and never had one self distruct. The first things to check would include the groove and the splines on which the gear slides. JimN
