3 point hitch not working right?
Hannibal
03-25-2007 08:19:40
I"m new to tractors, and have a couple of questions on the 3 ph on my IH 606 Diesel... The tractor had been sitting for 5 or 6 years outside when I bought it this fall, and last weekend I finally got it actually moving after fixing frozen clutch and brakes. Everything seems to be working well now, but I"m not sure that the 3 ph is working properly. When I raised it the first time it spit a bunch of rusty looking fluid out the hydraulic cylinders, but after that they seem to be fine (as in not leaking). However, in order to get the 3 ph to lower, I have to physically jump on the hitch arms while pulling the hydraulic lever in the "lower" position. Is this normal?? Should I be depending on the weight of the implement to lower the hitch?
Dan Bear Kelley
03-25-2007 08:36:41
 Just needs some work in reply to Hannibal, 03-25-2007 08:19:40
I'll bet your tractor just needs to be put to good use. That 3-pt will probably work itself free after a while. Tractors don't take kindly to sittin'.
My '51 M smoked like a house fire when I first got it. After spending time working the front loader hard movin' dirt and steel, she barely smokes at all. If I keep working her, I'll bet she stops smoking altogether.
Tractors know when they're needed and wanted.
Allan In NE
03-25-2007 08:26:35
 Re: 3 point hitch not working right? in reply to Hannibal, 03-25-2007 08:19:40
Use it and I'll betcha it will free right up on it's own.
Allan
