Farmall 'H' Flywheel Cracks
Joshua Lawton
03-25-2007 15:03:40
All:
Update to my '52 H project: I've got 'er split and have accumulated all of the parts to replace the ring gear and clutch (Clutch plate, Pressure plate, TO bearing and Pilot bearing). I was getting ready to put the new ring gear on my flywheel and happened to notice a lot of fairly deep cracks on the "clutch" surface of the flywheel. I'm wondering if this indicates replacement is necessary or if I can get away with it as it is? I'd rather not spend the cash, but don't want to cause a safety issue or have to split it again any time soon. Any thoughts?
CNKS
03-25-2007 16:15:18
 Re: Farmall 'H' Flywheel Cracks in reply to Joshua Lawton, 03-25-2007 15:03:40
Since you have it split, you might want to have it reground. That will not eliminate the cracks, but will make it smoother. Cracks are common; unless they are severe, whatever that means, I doubt if they are a safety issue.
Joshua Lawton
03-25-2007 17:11:15
 Re: Farmall 'H' Flywheel Cracks in reply to CNKS, 03-25-2007 16:15:18
Thanks for the info, CNKS.
Josh
