Farmall Hydraulics
Chris Zastrow
03-26-2007 13:29:45
I have been fighting with my 340 hydraulics for hours and am fed up with the system. It has the side mounted pump. I have tried three pumps. All Which look clean inside without any or very very minimal scores. How do you know if the pump is bad. Is there a special trick to priming the system. I have primed it through the hole on the pump. I even tried pressurizing the rear end with my air compressor. Still the whole system is dead. I also can find no air leaks in the system. The filter is clean and free. It could be the pump. Anything you guys know would be great.
Thanks
Janicholson
03-26-2007 18:06:11
 Re: Farmall Hydraulics in reply to Chris Zastrow, 03-26-2007 13:29:45
The pump drive could be failing (Im not sure, but do you know the system is spinning) Turn it by hand with the lines off in a bucket to make sure it pumps! Just thinking out loud, JimN
