How big a tire on b. n. puller
Thumper S
03-26-2007 18:26:13
How big a tire can be run on a b.n. with a good strong motor, in 2500-3000 ib.class. thanks
gene bender
03-27-2007 02:49:57
 Re: How big a tire on b. n. puller in reply to Thumper S, 03-26-2007 18:26:13
You could try a 15.5 on a 10in rim. Mite bee tto much as you didnt say what you are running now.
old
03-26-2007 21:09:16
Beleive it or not but if you can go smaller diameter and the wider your better off. Problem is if you go wide you also got bigger diameter which also means faster speed which you don't want. So you need wider but smaller diameter so you have more torque to the wheels but less speed.
Andrew Z
03-26-2007 19:14:57
If you got a non stock engine than 12.4-24 are and even 13.6"s if you have that much engine behind you. AS for going to a 28" rim A guy in out club did that and he had a pretty strong engine and it killed that B. It encreasd the ground speed way to much. I would stick with the 24" rim and 12.4"s - 13.6s
Andrew
