w-6 Steering?
Kirk In Ks,
03-27-2007 04:37:10
there's a big but on the end of the steering post on my W-6, it's the tightener I think,
If I adjust this ?
will It firm up the steering on this thing? I hope so as i cant find a steering gear to fit my tractor,
georgeky
03-27-2007 06:30:16
 Re: w-6 Steering? in reply to Kirk In Ks,, 03-27-2007 04:37:10
Kirk it appears I am wrong. I looked in the book which I should have done in the first place and it says that the steering on 6 series is to some degree. You will have to remove the worm and then remove the other gear that it contacts and turn it a little and put back on shaft. This is not really an adjustment just moving the point of contact to ride on teeth with less wear. It is simular to turning the sector gear on the farmall tractors.
georgeky
03-27-2007 06:21:13
Kirk, they are non adjustable. To adjust you will have to replace them.
hmmmm....
03-27-2007 05:47:17
Better try that again..... .
