INTERNATIONAL 240 UTILITY BRAKES HELP
GERRY GEIER
03-27-2007 06:54:29
MY BRAKES DO NOT WANT TO STOP ANY MORE I THINK THE SHOES ARE GLAZED HOW DO I GET ACCESS TO THE SHOES. DO I JUST REMOVE THE DRUMS WITH THE BOLTS THRU THE DRUMS OR IS IT MORE COMPLICATED. I THINK THE SONS LEFT THE PARKING BRAKE ON AN RAN THE TRACTOR SOME
Coax
03-29-2007 13:47:35
 Re: INTERNATIONAL 240 UTILITY BRAKES HELP in reply to GERRY GEIER, 03-27-2007 06:54:29
You should look at the Oil Seals behind the Bull Pinion Plate while you have it apart.Thats where mine failed, a big oily mess!
georgeky
03-27-2007 07:14:35
Gerry they have disc in them instead of shoes. They may only need a good cleaning. You do remove the drum to get to them and just put it back using reverse procedure. You should sand all the actuatiing balls and slots they ride in to assure proper function. Maybe even replace the springs. Sometimes you can sand the disc surface and help it, but if showing much wear I would replace those as well. Just as well fix them right while you are in there. Parts are available from IH or OEM. Here are some numbers. Marshalls Tractor Parts. 1-888-824-0544. OEM 1-800-283-2122.
GERARD GEIER
03-27-2007 11:47:57
 Re: INTERNATIONAL 240 UTILITY BRAKES HELP in reply to georgeky, 03-27-2007 07:14:35
SO IF I TAKE OFF THE BRAKE COVERS NOTHING WILL FALL OUT
georgeky
03-27-2007 13:22:34
 Re: INTERNATIONAL 240 UTILITY BRAKES HELP in reply to GERARD GEIER, 03-27-2007 11:47:57
Nothing should just fall out, but the brake assembly will slide off the shaft as you pull the drums. Go ahead and take it apart it is not hard at all.There is no way to learn except by diving right in on it. Just put it back together the same way it came apart. You will have to diconnect the adjustment rods from the brake pedals before taking the drums loose.
