Replacing Mag on M.D.
Lannie
03-27-2007 09:52:27
Would like to replace the Mag. on my 48 M.D with a distributor set up. Anyone ever done one? Have heard the distributor rotates opposite of a gas engine. If so anyone have a line on one? Any info on this project would be appreciated.
JohnG(TX)
03-28-2007 10:51:40
 Re: Replacing Mag on M.D. in reply to Lannie, 03-27-2007 09:52:27
I had a good distributor earlier, but sold it on eBay. It had no advance at all. All the advance mechanism was gone, and the shaft was solid, not split like in a gas application.
MAGMAN
03-27-2007 17:02:52
Yes just send it to me and be done with it I will rebuild her just like new and you wont need a distributor. JON
jakee
03-27-2007 13:26:59
yes the gas mag runs clock - wise, and the diesel runs counter clock-wise,the mag can be made to run either direction but you would need a blue ribbon shop manuel to learn how to do it. or find a old timer at one of the dealers,he would no how to do it.
El Toro
03-27-2007 11:41:17
third party image
Here's a mag that's been converted to a distributor. Hal
Janicholson
03-27-2007 11:34:15
Smd, SMDTA, 400D 450D, SWD6 and some others may be dist equipped. They do not need much in the way of advance, but the y do turn opposite. If in a pinch, a gas dist could be workable by locking the advance mechanism with a screw through the spring plates. Then timing it so it starts. (gap is .020")
JimN
gene bender
03-27-2007 11:14:48
Better check the rotation of the mag and see which way the rotor turns i have heard that the gears in the MD make the mag turn counter clockwise. Just get the mag to work.
