Shaving an M Farmall Head
Ole Rusty
03-27-2007 21:57:04
I am working on my head and was wandering if anybody new just exactly what the max. amount is that can be shaved off. I am running high dome pistons and believe the dome is .430. If you have any info I would apreciate it. Thanks
dej(Jed)
03-28-2007 12:40:15
 Re: Shaving an M Farmall Head in reply to Ole Rusty, 03-27-2007 21:57:04
Make sure you have a spare head and cut away.
The machine shop doesn't make the decision, you do. 1/4 of an inch should be no problem. Heck we have shaved heads and had to shim the plugs out to stop the pistons from smashing them..
randy hall
03-28-2007 12:32:43
you could use pistons with a one inch dome if you wanted to with a 8060 head. the limiting factor is the thickness of the casting at the bottom. i wouldn't take off over an eighth of an inch.
Ron in Nebr
03-27-2007 23:18:11
The real max amount probably varies some from head to head. Your machine shop could most likely do some measuring and come up with an amount that they feel comfortable taking off.
