Farmall A running rough
kazenza
03-28-2007 10:09:25
I have a 47 A that ran pretty well last year for mowing and such. However, I didn't notice that the weather cap apparently came off the muffler and as a result I got water down into the engine during a couple of storms this winter.
Now I can start it but it is running extremely rough and underpowered and blowing black smoke which it didn't used to do. I pulled the plugs and cranked it to blow any residue out of the engine. Replaced plugs just in case. Engine has a new carb and magneto and I've retimed it twice. Also just found a hole in the intake portion of the manifold, which may be part of my problem.
I'm wondering if the water that may have gotten in could have caused a stuck valve. Compression looks pretty even across the engine, but I'm starting to think overhaul. Any thoughts.
Randy, Jamestown CA
Roger Mills
03-29-2007 07:23:46
 Re: Farmall A running rough in reply to kazenza, 03-28-2007 10:09:25
Don't panic yet. On gas engines black smoke is too much fuel. Blue under load is usually rings, at idle it is usually valve stems, white is water/coolant, usually head gasket or cracks. Check to make sure choke is opening all the way, if so then the float is probably sticking (or sinking) keeping the needle off the seat. Simple to fix.
old
03-28-2007 11:42:32
As Jim says and also replace that manifold as it is part of the problem but since its blowing black smoke Jims probably get the answer there and you have a problem with the float or needle
Janicholson
03-28-2007 10:15:16
Intake system repair.
Carb is floding (possible sinking float) Th rich mixture. No overhaul needed yet. I would open the carb, and check the float system. Rattle the float to see if it is partially filled with gasoline. JimN
